It is currently Tue Jul 22, 2025 12:05 am
PostPosted: Thu Feb 22, 2007 4:52 am
I'm finally getting around to removing a fingerboard, and just before I started to get busy, I remembered that I had used CA in a few spots. The fingerboard was glued down using Titebond, but there were a few areas that I did some gap filling with CA, and now I'm wondering what temp I can expect it to release at -- or if it will release. Or will it release, and then after cooling, restick? I'm afraid I just don't have much experience with undoing CA glue joints.
Best,
Michael
Live to Play, Play to Live
PostPosted: Thu Feb 22, 2007 6:23 am
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
Can't give you an exact temp that superglue will let go, BUT...when removing frets that have been superglued in, I use a large old fashioned soldering iron, with a fret-sized groove in the tip to heat the fret AND vaporize the superglue. My best guess is that the superglue will vaporize/crystalize (and let go) at somwhere near the temp that solder melts (500+ degrees??). Once zapped this way it does not reset.
That's not going to help you with a wood to wood situation as you'll scorch any wood you try to heat to release the superglue.
Depending on where the glue line is, once the FB is warmed to loosen the tight bond you might try coming at the joint with a very thin spatula knife and try to shear between the two glued surfaces. Also if you can get the FB to lift a bit, you might be able to go at the joint with a single edged razor blade...thinner and sharper that a spatula knife would be.
One other thought..if you are not involved with a finished surface area (lacquer, varnish, etc) you might try to wick in some acetone at the superglue site to help soften the glue to open the joint.
Good luck...and let us know what method worked.
Hank Mauel
PostPosted: Thu Feb 22, 2007 6:28 am
Michael, you can buy a CA glue releasing agent/solvent. Why use heat when you don't have to?
PostPosted: Thu Feb 22, 2007 6:53 am
Generally speaking,
At 100°C (212°F)CA retains about 50% of its bond strength.
At 125°C (257°F) CA retains about 25% of its bond strength.
At about 130°C (266°F) CA bond strength is about zero.
PostPosted: Thu Feb 22, 2007 2:57 pm
remember that the fumes are nasty; ventilate and protect!!!!
PostPosted: Mon Feb 26, 2007 7:50 am
Guys,
Thanks for your replies. Sorry for not replying to them sooner -- haven't even turned on my computer for a few days.
Don, I like the releasing agent angle. I'll bet it'll play havoc with a shellac finish, though. Any worries about wood discoloration, do you know?
Best,
Michael
cron
